2019-04-19 12:41 AM
Hello ST,
We are facing some disconnection problem with BLUE-NRG MS. Where we have tested with many boards, the disconnection is happening at different time instances.
sometime the boards are connecting for longer time say 2 to 3 hours but sometime disconnects in 15 minutes. The only reason we are seeing while disconnection is CONNECTION TIMEOUT.
Why such behavior in same boards and what is reason for CONNECTION TIMEOUT ?
2019-06-06 09:06 PM
Hi Shivashekar,
I am facing a similar issue. Where you able to solve your problem? Thanks
2019-08-06 11:56 PM
looks like i am facing the same issue, have you solve yours?
