What is the status of the SPBTLE-RF BLE module ?
‎2018-06-27 7:46 AM
We're just completing a design based on the ST BlueTooth Low Energy module
SPBTLE-RF.
However, we are finding it very difficult to find any stock (in the UK at least)
SPBTLE-RF is marked as not recommended for new designs
SPBTLE-RFTR looks ok and appears to be just a different format (Tape & Reel)
But delivery times are anything from 5 weeks to a year !
Nucleo development boards for BLE are still featuring this module so I presume it isn't going to be superseded anytime soon ?
Thanks for any info anyone may have..
#ble #spbtle-rf- Labels:
BLE
Low Power RF Solutions
‎2018-06-27 8:06 AM
Packaging apart (tray vs T&R), modules are exactly the same.
XNucleo board will (can) mount TR modules if/when needed
‎2018-06-27 5:12 PM
I am seeing the same problem of availability here in the U.S.
Any information on long term availability would be helpful.
‎2018-06-28 12:41 AM
We can find the
SPBTLE-RF0 much easier here, so will be testing that in the design.
As far as I can see, the only differences are in certifications and Tx/Rx current consumption unless anyone knows anything different ?
‎2018-06-28 4:48 AM
RF/RFTR: SMPS power supply, LSE (32KHz) crystal, TELEC (Japan) certification
RF0/RF0TR: LDO power supply, no LSE crystal
‎2018-06-28 5:29 AM
Thanks for the info.
Does that mean the datasheet is wrong...
‎2018-06-28 6:22 AM
Do not confuse BlueNRG's mandatory HSE (16, or 32MHz here) with optional LSE (32KHz)
‎2018-06-28 6:43 AM
Sorry, I immediately read it as 32Mhz, not Khz.
Thank you
