2015-06-15 3:34 AM
Is there a limitation/restriction of of the WEP key lengths in AP mode?
Set password to 'test1':
AT+S.SCFG=wifi_wep_keys[0],7465737431 AT+S.SCFG=wifi_wep_key_lens,05 This works OK. I can connect fine with WEP authentication. However trying : Set password to 'test11': AT+S.SCFG=wifi_wep_keys[0],746573743131 AT+S.SCFG=wifi_wep_key_lens,06 Doesn't work I can't connet to the access point? However, if I change key to 14 bytes, and wep ley length to '0D' it seems to works again? Can the length only be '05' or '0D'? Thanks in advance. (P.S. I am running 3.4 firmware).2015-06-15 4:25 AM
2015-06-15 7:01 AM
Hi Toby,
Correct. wifi_wep_key_lens possible values are 05 and 0D ________________ Attachments : WEP_key_config.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1Hv&d=%2Fa%2F0X0000000bmi%2FSgXsQdCu6NIwrSNakVGtuzcqQr1tgUPHwByXhe8GKUY&asPdf=false
