STEVAL-IDW001V1 documentation?
vneff
Posted on April 28, 2014 at 16:28
I just received a STEVAL-IDW001V1 eval module.  It is meant to connect to a Discovery F0 board, but intend on using it with a STM32F215 processor based device.  I haven't found much documentation about this eval board.  I have:
STEVAL-IDW001V1 - Wi-Fi daughterboard for STM32F0DISCOVERY
which includes a schematic and a general outline of what the board can do.  No specifics as to what the jumpers are for, what the important connections are, etc.
STEVAL-IDW001V1 Schematic diagram
This seems to have no relation to the eval board???
SPWF01Sx - Serial-to-Wi-Fi b/g/n intelligent modules
This does, at least, give pin-out for the WiFi module being evaluated alond with some min/max ratings.
And, the most useful so far:
SPWF01Sx AT Command set reference guide
Is there any detailed info on the eval board, or is this it?
Thanks for any additional info!
Vance
3 REPLIES 3
Posted on May 05, 2014 at 12:21
Hi Vance,
we are working on st.com/wifimodules documentation. It will be more rich of informations from the end of May on.
- SPWF01S Datasheet -> go to www.st.com/wifimodules, click on SPWF01Sx, then ''Design Resources'' into new tab
- IDW001page:http://www.st.com/web/en/catalog/tools/PF260012 (again, click on ''Design Resources'')
In Attach:
-IDW001 HowTo
- SockServer HowTo
Thanks for feedbacks
________________
Attachments :
SPWF01Sx___Socket_Server.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0ei&d=%2Fa%2F0X0000000bmq%2FqQuJUohAQafLATflMqubVDecKW35zGMlUllBywbm.eg&asPdf=false
SPWF01Sx_and_STM32F0-Discovery.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1QC&d=%2Fa%2F0X0000000bmm%2Fw8MU4Vl4Y1RDXld9WADjkUcvMIG9SY3x_K8zB1V74ug&asPdf=false
artur
Posted on October 13, 2014 at 12:12
Welcome for the first time on this forum.
I try to use SPWF01S in my projects, unfortunately I met unsolvable problem for me.
I would like to ask you for the information, how to save a set of html pages to an IMG file (as in STEVAL-IDW001V1) so that it can be send to the module by a command AT + S.HTTPDFSUPDATE.
Which tool creates this file?
Best regards
Posted on November 20, 2014 at 03:36
sorry for delay.
Please contact your local ST support. He will send you that tool. It builds an ''*.img'' file, starting from a directory containing target filesystem content.
jerry
