2015-07-24 02:36 AM
My product will do FCCcertification,and the wifi module in my product is SPWF01.SA.
As FCC certification requiement,I need to set SPWF01SA as below: 11B-Ch1,Ch7,Ch13 11G-Ch1,Ch7,Ch13 11N-Ch1,Ch7,Ch13 I can configure the channel num by AT command successfully,but I don’t know how to configue the module to 11B ,11G or 11N. Pls help me for this problem. Thanks Peter2015-07-27 05:25 AM
you can use: - wifi_opr_rate_mask to set b/g/n (together with wifi_ht_mode for n)- wifi_channelnum to set the channel (if you are in miniAP mode)Regardsjerry
