SPWF01SA.11 connection to AP
anonymous.230621_1419
Posted on July 27, 2015 at 14:03
The original post was too long to process during our migration. Please click on the attachment to read the original post.
4 REPLIES 4
Gerardo GALLUCCI
Posted on July 27, 2015 at 14:21
Please update your FW.
Are you sure your AP is set with WPA2 key? Scan command gives you ''WPA'', not ''WPA2''...
j
Posted on July 27, 2015 at 14:41
Hello Gerado,
yes, you are right Key is WPA not WPA2.
Is there any difference, in AT Commands ?
Or just FW upgrade will fix it ?
Best regards,
Alex
Gerardo GALLUCCI
Posted on July 27, 2015 at 14:48
I don't know if it fix the problem, but updating the FW we'll be able to get the deauthentication reason code after WIND:40.
It's a better starting point...
j
Posted on July 27, 2015 at 15:44
I've tested it now with an other Ap.
The module ony has problems with WPA. WPA2 is working fine
Thanks for your help.
