2016-03-16 8:03 AM
Hi All,
For my project i am using SPMW01SA WiFi module and still we are in development stage so we are doing our R&D on STEVAL-IDI004v2 evaluation board.STEVAL-IDI004v2 board WiFi is able to connect to internet and when we are trying to send sensor data to cloud WiFi module is responding back with arguments are missing. Our cloud is expecting data in JSON format and HTTP post method.Can anyone please help me on this.Regards,--Manz #https://my.st.com/public/ste2eco2016-03-16 8:14 AM
you can try using FW3,5 and HTTPREQ commandBRj2016-03-22 1:22 AM
Hi Manz,
does it work with the new firmware? Some of us are trying to send a http post to the Android GCM server, that also accepts posts in JSON format. https://my.st.com/public/STe2ecommunities/interface/Lists/WiFi%20Modules/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2finterface%2fLists%2fWiFi%20Modules%2fHTTPPOST%20Example%20Android%20GCM&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800086789498A6852D4897EA192EB1DEE909&TopicsView=http... But I still don't get it working. Maybe you can post the commands of your solution. Cheers, Flow2016-03-24 8:26 AM
Hi Flow,
did you try something like this...?u8 request[] = ''POST /blog/postsAccept: application/jsonContent-Type: application/jsonContent-Length: 57{''title'':''Hello World!'',''body'':''This is my first post!''}
\r\n\r\n''u8 command[] = ''at+s.httpreq=IP,port,sizeof(request)\r''and issue command+request over module UARTj2016-03-25 1:30 AM
Hi Jerry,
thanks for your example. I tried a lot, but don't get the page to accept the content lenght: I send: AT+S.httpreq=android.googleapi.com,80,388 and after that I send the post data: POST /gcm/sendAccept: application/jsonContent-Type: application/jsonContent-Length: 243 ... followed by the JSON content I receive always the answer, that the length is required... HTTP/1.0 411 Length Required Content-Type: text/html; charset=UTF-8 Content-Length: 1564 Date: Fri, 25 Mar 2016 08:24:42 GMT <!DOCTYPE html> <html lang=en> <meta charset=utf-8> <meta name=viewport cont ent=''initial-scale=1, minimum-scale=1, width=device-width''> <title>Error 411 ( Length Required)!!1</title> <style> *{margin:0;padding:0}html,code{font:15 px/22px arial,sans-serif}html{background:#fff;color:#222;padding:15px}body{margi n:7% auto 0;max-width:390px;min-height:180px;padding:30px 0 15px}* > body{backgr ound:url(//www.google.com/images/errors/robot.png) 100% 5px no-repeat;padding-ri ght:205px}p{margin:11px 0 22px;overflow:hidden}ins{color:#777;text-decoration:no ne}a img{border:0}@media screen and (max-width:772px){body{background:none;margi n-top:0;max-width:none;padding-right:0}}#logo{background:url(//www.google.com/im ages/branding/googlelogo/1x/googlelogo_color_150x54dp.png) no-repeat;margin-left :-5px}@media only screen and (min-resolution:192dpi){#logo{background:url(//www. google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) no-repea t 0% 0%/100% 100%;-moz-border-image:url(//www.google.com/images/branding/googlel ogo/2x/googlelogo_color_150x54dp.png) 0}}@media only screen and (-webkit-min-dev ice-pixel-ratio:2){#logo{background:url(//www.google.com/images/branding/googlel ogo/2x/googlelogo_color_150x54dp.png) no-repeat;-webkit-background-size:100% 100 %}}#logo{display:inline-block;height:54px;width:150px} </style> <a href=//ww w.google.com/><span id=logo aria-label=Google></span></a> <p><b>411.</b> <ins> That’s an error.</ins> <p>POST requests require a <code>Content-length</code > header. <ins>That’s all we know.</ins>2016-03-25 1:45 AM
Only for debug...
did you already tried to send nothing? I mean, using ''Content-Length: 0
2016-03-25 6:13 AM
Hi Jerry,
I tried it... but I get the same response :\ Cheers, Flow2016-03-25 6:20 AM
Bad :(
My suggestion is to switch for a while from SPWF01S to a simple Netcat utility tool running on PC. Once request string is sane, you can switch again to module, and include that string...I hope someone else can give you some useful information...j2016-03-25 10:11 AM
Hey J,
I played a little bit with wireshark. I sniffed the packets send by my PC program, that works with gcm. I've seen there, that between the Content-xxxx messages are \r\n. So I tried this also with the SPWF. But when I have there \r\n between e.g. ''Content-Type'' and ''Content-Length'', I didn't sniffer any HTTP packets any more, just tcp packets. Without the \r\n, I also sniffer HTTP packets send by the SPWF. Do you have an idea why didn't sniff any HTTP packets when I have the \r\n in my header? Thx & regards, Flow2016-03-29 2:03 AM
Hi Flow,
no idea for this. Bytes you see in the wireshark, are the ones you fill in the module by HTTPREQ command. Module does not append nothing by itself. Second picture shows a ''Truncated'' request. The string ''POST something HTTP/1.1'' is really ''POST something other...''. Seems like string provided to HTTPREQ is not well formatted. Try to sniff the UART link between module and external MCU. Try also to put a delay between HTTPREQ command's <CR> and following payload (request string), just to be sure that characters are not lost over serial line. Let me know. j
