Sigfox_CLI_Demo_Project command values for start_continuous_transmission
CChon.0
I am trying to trigger the start_continuous_transmission for the sigfox CLI demo but it returns an error 0x0058 when I debug. What are the values to trigger it ? I tried editing the code to fit in the frequency manually but it still returns an error.
void SIGFOX_API_start_continuous_transmission_Action(void)
  sfx_u32 frequency=(uint32_t)920800000; //(uint32_t)unsignedCommandArgument(0);
  sfx_modulation_type_t mode=(sfx_modulation_type_t)0;
 //unsignedCommandArgument(1);
//0 for unmodulated
  sfx_error_t err;
  err=SIGFOX_API_start_continuous_transmission(frequency, mode);
  responsePrintf("{&N API call...&tx}\r\n",
		 "SIGFOX_API_start_continuous_transmission", "sfx_error", err);
I couldn't find the parameters in the documentation or code. Please help.
Thank you
Best regards,
Chong
Thomas LB
I know it's late but I've searched for it for 5min so maybe it will be helpful for someone:
just type:
start_continuous_transmission 868000000 0
read UM2169 for details (https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/8d/9a/ea/d7/62/06/43/ce/DM00361540/files/DM00361540.pdf/jcr:content/translations/en.DM00361540.pdf)
This morning a reproduced the sfx_error:58
If you do
"node_open" before "start_continuous_transmission 868000000 0" you got error 58
just don't do "node_open" and your good
