‎2021-06-21 02:29 AM
I'm trying to setup a client & server pair that work like the following:
Is there any examples for extend advertising & establishing connection with it? How do i setup AUX_SCAN_RSP if an active scanner is sending AUX_SCAN_REQ?
BLE_RC_LongRange is not what i want, as it is using fixed address for connection, and no scan response data is setup when using coded PHY.
Many thanks
‎2021-06-25 07:05 AM
Solved.
‎2022-07-26 06:16 AM
that good to hear. if possible share an example or how you solved it🙂
