Python scripting for BlueNRG
rdscliff
Posted on July 12, 2016 at 20:24
Can BlueNRG scripting work as a full Python program?  Questions I have:
  • Can scripts be run in a normal Python debug environment rather than using BlueNRG_Script_Launcher to run?
  • Can I import standard Python modules into my BlueNRG GUI script?
  • Is there a BlueNRG module or package I can import to add Bluetooth capabilities to a normal Python program?
5 REPLIES 5
Posted on July 13, 2016 at 14:30
Dear customer,
I'll try to give a feedback to you:
•Can scripts be run in a normal Python debug environment rather than using BlueNRG_Script_Launcher to run?
- No the scripts written for BlueNRG device cannot be runned in a normat Python debug because they contain special command understanding only using BlueNRG_Script_Launcher or GUI.
•Can I import standard Python modules into my BlueNRG GUI script?
Yes, you can import any standard Python modules into BlueNRG GUI script.
•Is there a BlueNRG module or package I can import to add Bluetooth capabilities to a normal Python program?
No
Graziella Marchese
rdscliff
Posted on July 13, 2016 at 22:24
Thank you. That was very helpful.
Mk Sundaram
Posted on July 25, 2016 at 10:46
Very useful. Thank you
Posted on December 08, 2016 at 20:24
I tried to include very simple package 'import json' in the script and it failed. Would appreciate if you let me know why I am facing the issue. As per your answer above, python scripts are normal python and should be able to include any python packages.
My question:
https://community.st.com/0D50X00009XkYcaSAF
Posted on December 12, 2016 at 11:38
Dear Customer,
normally the import works, probably you have any problem with json package.
