2020-07-17 12:20 AM
Three weeks earlier, I connected for the first time my STEVAL-FKI868V2 to the Sigfox backend and used the S2-LP_SigFox_DK-GUI (v.1.7.0) tool to send test messages to this Sigfox backend. Everything worked perfectly.
Now since 6 days I try again to send test messages with this tool, but nothing is received on the backend.
What I already tested:
I don't know what to do, where the mistake can be, and if this problem has already appeared to other people.
I hope someone here can help me.
Laurent
2021-03-03 12:58 AM
Can you please give following commands using terminal and check response:
What about tick : Use Public Key?
2021-05-27 06:35 AM
Laurent,
I started using the S2-LP_SigFox_DK-GUI yesterday. Was seeing the same symptoms (i.e. Response timeout) as you. I had been sending my transmissions from inside my home so I decided to send the transmissions from outside. When I was outside I started to get responses from Sigfox. However, I did not get the responses every time. My conclusion is that I have some signal level or SNR issue in my area. Not a technical response but I hope this helps you.
Regards, Mark
2021-05-30 11:28 PM
For information, when there is a coverage issue, user may consult Sigfox for support.
