2022-01-11 7:12 PM
2022-01-12 1:53 AM
Welcome, @XZHAN.2, to the community!
I've translated your question using a translation tool, since the majority interact in English:
L99MM70XP is in stock and there is only a 500PCS option on it. How can I buy it if I need the whole tray? It's urgent. Is there a hotline?
You mean the estore.st.com, right?
If you need more than 500 pieces, you should contact us, typically a distributor you are comfortable with, which you can find on the Contact Site.
Good luck!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
2022-01-12 1:53 AM
Good luck!
/Peter
