2023-12-07 6:04 AM
Hey, I am a new user at this forum sorry for any lack in communication.
I have an IO-Link sensor and would like to interface it with Arduino uno and after research found STEVAL-IOD003V1 IO-Link transceiver and found it helpful for my application I wanted to know if there is any library available to interface it with Arduino uno or any set of commands necessary to provide it for best working. Help in any form would be great Thanks a lot in advance for taking time for me.
This is the product https://estore.st.com/en/steval-iod003v1-cpn.html
These are data brief and user manual for the same
2023-12-08 12:05 AM
Welcome @Devanshu, to the community!
In principle, you can also use an 8bit MCU to control the L6362A, which is used on the STEVAL-IOD003V1, but it makes a lot of sense to use an existing stack for IO-LINK. STMicroelectronics does not offer a stack itself and works together with its partner TEConcept, which has also developed one for STM32. So if you want to work with IO-LINK, the easiest way is to license the software from TEConcept.
For Arduino at least STMicroelectronics cannot help you.
Hope that helps?
Good luck!
/Peter
