2020-02-06 10:25 PM
2020-02-09 09:07 PM
Are you using the latest SDK on an ST EVAL board ? Kindly specific which board you are using ?
Also, latest Android app is used ?
Kindly check if during the provisioning, the binding to Generic OnOff Model was done or not ?
Hope the "Vendor Model" is not enabled from the menu on the left side of the App. If yes, kindly check to bind the Vendor Model please
