in sw package BlueNRG-2 “over-the-air�? (OTA) firmware upgrade what happened in case :
1 - power failure during upgrade?
2 - lost of BLE during update?
in configuration OTA service manager framework
2023-06-05 7:35 AM
2023-06-05 8:59 AM
2023-06-05 10:59 PM
Refer to:
AN4869: The BlueNRG-1, BlueNRG-2 BLE OTA (over-the-air) firmware upgrade
With the OTA service manager framework, the firmware will be corrupted. The user has to restart the OTA upgrade procedure.
With the reset manager and the higher/lower application approach, the new firmware is corrupted too. But, the old firmware application can still work, since only (approximately) half of the flash memory was to be upgraded.
2023-06-06 1:37 AM
When BLE communication is lost, reestablishing the OTA upgrade procedure happens automatically after a timeout or requires a manual reset?
