Hi, I use the SPWF04 and i want know: Is it possible to open automatically a web page on a smartphone when it is connected at the Access Point? Best regards Patrick
Patrick Papin
6 REPLIES 6
Elio Cometti
Senior II
​Hi Patrick,
could you detail your use case?
  • Is the SPWF04 configured as MiniAP and you want to open a web page when you associate a smartphone to SPWF04?
  • is the SPWF04 configured as Station and you want it to open a web page on a smartphone when SPWF04 associate to an Access point?
  • what else?
Thanks,
Elio
Patrick Papin
Hi Elio,
the SPWF04 is configured as MiniAP and when the smartphone is connected to the mini AP:
Automatically a web page open on the smartphone
Best regards
Elio Cometti
Senior II
​So, you want to implement something like a captive portal?
Patrick Papin
Yes exactly,
How configure the SPWF04 for that?
Patrick Papin
Hi Elio,
I configure the SPWF04 like this:
-ip_apredirect= stra.html (my Web page)
but that don't work! (No page found at captive portal)
What are the parameters to configure the captive portal?
Best regards
Elio Cometti
Senior II
​Hi Patrik,
it seems not possible to enable this feature because the DNS on SPWF04 only respond to requests for the domain specified in ip_apdomainname.
The smartphone make several DNS and http requests before opening the popup and all must be served otherwise the popup is not opened.
ip_apredirect specifies the page that must be sent when the default page (http://<SPWF04's IP>/) is opened.
