Cannot to use BlueNRG-1 with internal 32 kHz oscillator.
VKolo
If I changed the definition LS_SOURCE=LS_SOURCE_INTERNAL_RO, the procedure DeviceConfiguration() stopped in line "while(CKGEN_BLE->CLK32K_IT == 0);"
It seems that the internal generator 32 kHz does not work.
How I can to turn on generator 32 kHz.
Winfred LU
Hi MicroLine,
I've just tested again and
It works for me normally.
Could you please try STEVAL-IDB007V1 or V2 with the latest DK (v3.0.0)
https://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-bluenrg1-dk.html
and modify project Options | C/C++ Compiler | Defined symbols, then set
Thank you.
Best Regards,
Winfred
