BlueNRG-MS. Do not work "scan response" after one day working
GGeor.10
So, After a couple days working. BlueNRG-MS do not answer on "scan request". All other functions work, i can connect/disconnect, write/read gatt properties... I work with Aci_Gap_Set_Discoverable. I found only one case for resolving. It is reboot. It is bad solution.
Scott Löhr
Senior II
Can you give a more detailed description - if you cannot initiate a scan request, how can you connect? Which API is called exactly, etc.?
