2021-01-05 03:41 AM
Hi i am using Bluenrg 2 m2sp as network processor mode , Here when i sent aci_gatt_update_char_value_ext command , some times i getting getting invalid command response . may know the reason , if i get invalid response , shall i retry same command once .
Regrds
Manukumar
2021-01-11 09:28 PM
I think those might be Invalid HCI Command Parameters (code 0x12).
Please check the differences between successful and failing commands. Possibly some parameters were incorrectly configured for the failing cases.
2021-01-29 10:59 PM
Thanks Winifred your response , i will check which command parameter are incorrect during the response
