BlueNRG-LP Mesh example missing.
Mgupt.2
Hi everyone,
I am new to the ST world and I'm having some doubts about my evaluation.
I'm researching for the BlueNRG-LP controllers. As I am sure that the LP series support Ble Mesh so why can't I find the Mesh example for BlueNRG-LP in the STSW_BNRG_Mesh(It contains only BlueNRG-1 and BlueNRG-2 examples) SDK. Kindly help me to find valuable resources using which I can develop the Mesh application on BlueNRG-LP.
Kamal
You can find the mesh example for BlueNRG-LP device on below link:
https://www.st.com/en/embedded-software/stsw-bnrglp-mesh.html
Kamal
a few seconds ago
Actions for this Feed Item Comment
Hi Kamal,
This is exactly what I am looking for. Thanks for the help.
I would like to ask you for one more thing. I am planning to design a Mesh solution based on the BlueNRG-LP controller but I have been confused.
As you can see on this datasheet the schematic of "STEVAL-IDB011V1" shows the PCB antenna option but the schematic file from here does not include the PCB antenna.
I want to know which one shows the correct/updated info.
And can you guide me to the resource where I can find the latest hardware design files for the evaluation board "STEVAL-IDB011V1"
Kamal
"STEVAL-IDB011V1" board is having SMA connector(J1) to connect external antenna and does not have PCB antenna. For latest hardware design file you can use below link.
https://www.st.com/en/evaluation-tools/steval-idb011v1.html#cad-resources
