2019-07-22 05:51 PM
I have semi-successfully imported the BlueNRG BLE_SensorDemo_BlueMSapp demo code using the STMCubeIDE TrueStudio import wizard, flashed it, and run it on the STEVAL-IDB007V1M with the BlueNRG android app.
the wizard asks for the M0 version.... I chose the first one as I could not find the M0 cortex processor in any SPBTLE-1S documentation. which one is it actually? the first choice in the list ran, and streamed pressure and temperature, but I need to make sure its the right selection.
Next step will be to port this reference code to my SPBTLE-1S design. I need to have access to the correct architecture, so knowing which M0 to choose is kinda important
thanks
Ted
2019-07-26 04:14 AM
turns out Keil uvision works. but I have to pay $1600
should have stuck with arduino
2019-07-26 02:59 PM
That's not exactly true. Keil is free for all ST devices based on Cortex M0.
Please refer to Keil website:
https://www2.keil.com/stmicroelectronics-stm32/mdk
Best regards,
ST Support
2019-07-26 03:02 PM
the SPBTLE-1S is advertised to integrate a Cortex-M0 on both the product page and the datasheet:
Product page: https://www.st.com/en/wireless-transceivers-mcus-and-modules/spbtle-1s.html
DS: https://www.st.com/resource/en/datasheet/spbtle-1s.pdf
Best regards,
ST Support
2019-07-27 02:58 AM
2019-07-29 08:56 AM
no, there is no code size limitation. Keil is free for all ST devices based on Cortex M0 with no code size limitation
and follow the procedure to activate the permanent license.
Best regards,
ST Support
2019-08-26 08:45 AM
Have anyone find proper way to develop BlueNRG-1/2 on STM32CubeIDE? I'm very interested.
Keil is good but I like to work on Linux. Keil seems like no plan to support on Linux and I don't want to bother to create a virtual machine over Linux.
One of workaround could be to chose a M0 based ST micro on STM32CubeIDE and then tweak the Link file manually.
A question to ST support, how difficult it is to support BlueNRG-1/2 on STM32CubeIDE natively? Will ST do it?
