BlueNRG EVAL not recognized by windows
berge
Posted on March 13, 2014 at 16:16
Hi ST
The evaluation board is not working properly. Windows does not recognize device at all. I guess that the board is missing  a USB pull-up resistor . but once soldered the pull-up resistor, windows recognizes the USB-cable but does not still recognize it as a virtual serial port. Can you help me ?
Posted on March 13, 2014 at 16:41
this behaviour is expected, since the BlueNRG kit is preprogrammed with a firmware to interact with a mobile phone (SensorDemo).
No hardware modification is required.
In section 3.1, the kit user manual specifies how to reprogram the STM32L firmware for controlling the BlueNRG through the GUI.
Here it is the web link
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00099259.pdf
Graziella
