BlueNRG-2 dual role configuration
IPavl.3
Greetings,
I am developing a multi-slave configuration using a few BlueNRG-2 modules where the master would also connect to a smartphone and transmit data collected from the slaves (a tree network). Though a dual master-slave (central-peripheral) role is possible, the question is if this also possible to assign specific aci_gap_set_io_capability() and aci_gap_set_authentication_requirement() for each gap role in the master device? Say, IO_CAP_NO_INPUT_NO_OUTPUT for the slaves and IO_CAP_KEYBOARD_DISPLAY for the smartphone?
1 REPLY 1
Billy OWEN
Hi @IPavl.3​
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
