B-L072Z-LRWAN1 - Not able to send more than 11 bytes of application payload.
KK.4
I am using I-CUBE-LRWAN SDK LoRaWAN_End_Node application. In LmHandler.c file inside LmHandlerSend() function LoRaMacQueryTxPossible() fails with LORAMAC_STATUS_LENGTH_ERROR. I have tried with higher data rates and also tried disabling the adaptive data rate. Request some help and insights on the same.
Note: Gateway and end-node are near to each other.
polgu.1
I have the same problem in a NUCLEO-WL55JC1 with LoRaWAN_End_Node application. Were you able to fix it?
