Will the same cover glass I am using for the VL53L1x work for the VL53L5CX as well? while I found a reference to this cover glass in the VL53L1x data sheet, there is no recommendation for the newer part. I am using the Hornix IR080C0-IC09-A066-2
chipmc
John E KVAM
No - the L5 sensor is larger.
But by now the new cover is up on the Hornix web site.
Everything about the L5 coverglass is the same - except it's size.
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
