VL53L0X - IR penetration through polycarbonate
AMans.1053
Hello, we are planning to assess VL53L0X to be used inside a polycarbonate casing, to measure the distance of an object, for e.g. a car parked over it. Can the IR penetrate through the plastic casing?
Arif
John E KVAM
Sure.
Polycarbonate, Acrylic and PMMA are all perfectly fine coverglasses. Near I/R Photons go right through them.
But there is a limit. Try to design your coverglass so that it's as thin as you can make given your other constraints.
And try to jam the sensor as close to the glass as you can get it.
You will get some crosstalk - but it can be calibrated out.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
AMans.1053
Thanks for your response John. Does the PC have to be transparent to human eye? As the casing we have is black in color and opaque to human eye.
