VL53L0X API Status: -50 : Reference Spad Init Error (VL53L0X_1.0.2 hack)
jgnoss
That's not meant as a question, more as an input/feed-back for ST developers or users of the VL53L0X device.
I have a custom PCB with STM32F091 and two VL53L0X
Symptom:
If I initialize one only of the sensors, that sensor works great and gives good results.
No matter if it is the left or the right one.
If I initialize first one sensor, (changing device address while initializing)
then the other (also changing device address while initializing),
the second sensor while initializing always runs into
My setup
custom PCB with STM32F091 + usual components on PCB TOP
2 VL53L0X devices 23cm apart on PCB Bottom.
STM32CubeIDE
Version: 1.4.2
Build: 7643_20200813_1322 (UTC)
VL53L0X_1.0.2 API from en.STSW-IMG005
slightly modified platform stuff in order to run on bare metal
Nucleo or discovery st-link to program the device
I traced the error down to
vl53l0x_api_calibration.c
line 594
		/* Confirm that the next good SPAD is non-aperture */
		if (is_aperture(start + nextGoodSpad) != apertureSpads) {
			/* if we can't get the required number of good aperture
			 * spads from the current quadrant then this is an error
				status = VL53L0X_ERROR_REF_SPAD_INIT;
				break;
this evalates to true if index in the enclosing for loop is
spadCount - 2
so I did the dirty hack
			//FIXME crude hack to get pass second sensor the spad management
			if (index < spadCount - 2) {
				break;
and it seems to run OK.
here a console output with original code and the error occures
VL53L0 Test 00.01 from Nov 25 2020 at 08:52:15.
Hello Ju
>init_ToF for Device RIGHT
Ack on Adress : 0x29
call VL53L0X_DataInit
>API Status: 0 : No Error
Device RIGHT DataInit complete
call VL53L0X_SetDeviceAddress
Device RIGHT VL53L0X_SetDeviceAddress complete
call VL53L0X_GetDeviceInfo
>Device Type : VL53L0X
Device ID : VL53L0CXV0DH/1$C
Call of VL53L0X_StaticInit
Call of VL53L0X_PerformRefCalibration
Call of VL53L0X_PerformRefSpadManagement
refSpadCount = 11, isApertureSpads = 0
Call of VL53L0X_SetDeviceMode
init_ToF for Device LEFT
Ack on Adress : 0x1E
Device LEFT DataInit complete
Device LEFT VL53L0X_SetDeviceAddress complete
... and after the modification
Hello Ju
refSpadCount = 10, isApertureSpads = 0
ready for ranging press 'r' for start/stop
first measured data while moving a white paper back and forth in front of the two sensors after code modification
r
Sensor LEFT Ranging activated
Sensor RIGHT Ranging activated
>Call of VL53L0X_StartMeasurement
LEFT   128
RIGHT   130
RIGHT   139
RIGHT   128
RIGHT   141
RIGHT   128
RIGHT   142
RIGHT   128
RIGHT   128
LEFT   128
RIGHT   137
RIGHT   136
LEFT   133
LEFT   128
LEFT   132
RIGHT   133
RIGHT   129
RIGHT   152
LEFT   150
RIGHT   147
LEFT   148
RIGHT   145
LEFT   132
RIGHT   133
LEFT   128
RIGHT   40
LEFT   32
RIGHT   17
LEFT   10
RIGHT   16
RIGHT   0
LEFT   0
RIGHT   2
LEFT   4
RIGHT   4
LEFT   10
RIGHT   16
LEFT   20
RIGHT   18
LEFT   131
RIGHT   128
LEFT   134
RIGHT   128
LEFT   136
RIGHT   132
LEFT   128
Ranging Sensor LEFT deactivated
Ranging Sensor RIGHT deactivated
>Call of VL53L0X_StopMeasurement
Wait Stop to be completed
Stop completed Sensor LEFT
Stop completed Sensor RIGHT
2 REPLIES 2
John E KVAM
You only need to do SPAD calibration once. It, along with offset and crosstalk, can be stored in memory and reloaded at boot.
So if you get a failure when the other chip is on - and I find this very strange - but you can...
Boot one sensor do all the calibrations, store them, and shutdown the sensor.
Then do the same thing on the other sensor.
Then boot, change the address, load the calibarion, boot the other sensor, change it's address and load it's calibration.
At that point you should be good to go.
I always tell people that the sensors do not interfer with each other.
But your experiment seems to show that one cannot do a RefSpad calibration with another sensor running nearby.
And that might be the issue. If so that might answer problems others are having.
Can you try getting one booted do the RefSpand cal - but DON't START IT. Then get the other booted and do the refSpad calibration.
Once both the calibrations are done, Then start them ranging. Does that work?
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
jgnoss
Hello John,
thanks for looking into that.
I'm afraid I already do that. At least if
VL53L0X_StartMeasurement(&VL53L0XDevs[i]);
is what starts the sensor.
I have two functions, one is setting up the sensors, doing all that calibration stuff.
That happens once, before entering the main loop, and takes up to 20s for both sensors.
The other function is called in the main loop to detect a directional swipe.
The code is mainly coming from the STM examples.
int setupDirSwipe(void) {
	int status = 0;
	// so enable both sensors */
	VL53L0XDevs[SENSOR_LEFT].Enabled = 1;
	VL53L0XDevs[SENSOR_RIGHT].Enabled = 1;
	dbg_printf(DEBUG_LEVEL_UI, "standby for setup and calibrate sensors \n");
	//We implement DIRECTIONAL_SWIPE only
	/* Initialize directional swipes recognition :
	 * swipe detected below 400 mm, no max speed,
	 * min duration is 1 sec for a swipe and
	 * hand must not cover both devices */
	status = tof_gestures_initDIRSWIPE_1(swipeDistance, min_SwipeDuration,
			max_SwipeDuration, coverBothSensorsRequired, &gestureDirSwipeData);
	/* Setup sensors in single mode */
	if (status == 0) {
		status = setupSingleShot();
	} else {
		dbg_printf(DEBUG_LEVEL_ERROR, "setupSingleShot failed\n");
		__Error_Handler(__FILE__, __LINE__);
	if (status != 0) {
	return status;
/**** main State machine functions *******************************/
mainSMState_t do_ReadyForDetection(mainSMState_t oldState) {
	// just sitting here and wait for someone activating swipe detection
	return ReadyForDetection;
mainSMState_t do_SwipeDetection(mainSMState_t oldState) {
	uint8_t status;
	uint8_t nReady = 0;
	int i;
	uint8_t NewDataReady = 0;
	int gesture_code;
	int32_t leftRange;
	int32_t rightRange;
	/* kick off measure on enabled devices */
	for (i = 0; i < SENSOR_COUNT; i++) {
		if (!VL53L0XDevs[i].Present || !VL53L0XDevs[i].Enabled)
			continue;
		status = VL53L0X_StartMeasurement(&VL53L0XDevs[i]);
		if (status) {
			dbg_printf(DEBUG_LEVEL_SENSOR,
								"VL53L0X_StartMeasurement failed on device %d", i);
		VL53L0XDevs[i].Ready = 0;
		//dbg_printf(DEBUG_LEVEL_SENSOR,"StartMeasurement %d OK ", i);
	/* wait for all enabled devices to have a measure */
	nReady = 0;
	do {
		HAL_Delay(1);
			/* Skip devices not present or not enabled */
				continue;
			/* Is new sample ready ? */
			status = VL53L0X_GetMeasurementDataReady(&VL53L0XDevs[i],
					&NewDataReady);
			if (status) {
									"VL53L0X_GetMeasurementDataReady failed on device %d",
						i);
			/* Skip if new sample not ready */
			if (NewDataReady == 0)
				continue;
			/* Clear Interrupt */
			status = VL53L0X_ClearInterruptMask(&VL53L0XDevs[i], 0);
			/* Otherwise, get new sample data and store */
			status = VL53L0X_GetRangingMeasurementData(&VL53L0XDevs[i],
					&RangingMeasurementData);
			if (status) {
									"VL53L0X_GetRangingMeasurementData failed on device %d",
						i);
			/* Data logging */
			 trace_printf("%d,%u,%d,%d,%d\n", VL53L0XDevs[i].Id, TimeStamp_Get(),
			 RangingMeasurementData.RangeStatus,
			 RangingMeasurementData.RangeMilliMeter,
			 RangingMeasurementData.SignalRateRtnMegaCps);
			sensor_SetNewRange(&VL53L0XDevs[i], &RangingMeasurementData);
			VL53L0XDevs[i].Ready = 1;
			nReady++;
	} while (nReady < nSensorEnabled);
	/* GESTURES : Apply gestures detection functions on the measures                */
	/* Clip ranging values as tof_gestures_detectDIRSWIPE_1 function must be called all the times to detect the gesture */
	leftRange =
			(VL53L0XDevs[SENSOR_LEFT].RangeStatus == 0) ?
					VL53L0XDevs[SENSOR_LEFT].LeakyRange : 1200;
	rightRange =
			(VL53L0XDevs[SENSOR_RIGHT].RangeStatus == 0) ?
					VL53L0XDevs[SENSOR_RIGHT].LeakyRange : 1200;
	gesture_code = tof_gestures_detectDIRSWIPE_1(leftRange, rightRange,
	if (gesture_code == GESTURES_SWIPE_LEFT_RIGHT) {
		wheelsInTunnel++;
	} else if (gesture_code == GESTURES_SWIPE_RIGHT_LEFT) {
		wheelsInTunnel--;
	} else {
		//ShowGestureHelpMsg(gesture_code);
	return SwipeDetection;
