2025-05-12 5:14 PM
I wish to connect the P-board, which has a 22-pin connector, to a Raspberry Pi that has a 15-pin camera connector (From the Raspberry Pi 1/2/3/4 series, not the 5). The datasheet for the P-board only gives a vague suggestion. Is there a specific cable that has been known to work?
2025-05-12 6:20 PM
2025-05-12 6:20 PM
Hi JohannH,
You can use a standard to mini FPC from this link
