2020-04-28 5:36 AM
Hi, the STA8089FGBD is an GNSS IC that supports DRAW, but it does not integrate an embedded IMU, I want to connect an external IMU to be able to use DRAW, but I cant find any hardware or sofware reference design to achieve this, does anybody have any idea about a reference guide or something like that?, ST has the TESEO3DRAW EVB to develop this solutions but what happen when you want to desig your own PCB with that solution?, there is no documentation to do that (at least I have not found it), thanks
2020-04-28 6:35 AM
Hi
STA8089FGBD is a TeseoIII ale to run DRAW but IMU sensor has to be connected external to Teseo3 (on I2C or SPI port)
BUT STA8089FGBD is sold in >10K units. It isn't available in low volume or via Distributor.
Francesco
2020-04-28 6:06 AM
Support and documentation for chip down usage is usually only shared with partners doing >$1M annual business. You should discuss your plans with your local sales office/rep.
2020-04-28 6:35 AM
Hi
Francesco
2020-04-28 8:29 AM
Hi, but the STA8089FGBD is available from 1 unit in Mouser
