device configuration tool is not generating
‎2025-02-16 8:22 PM - last edited on ‎2025-02-17 4:48 AM by Andrew Neil
‎2025-02-16 8:35 PM
The error messages says you should login. I suggest logging in and trying again. The myST menu is in the menu bar.
‎2025-02-16 8:35 PM
‎2025-02-16 8:47 PM
i have also logged in many times
‎2025-02-16 10:13 PM
This happen to me when I am using a VPN with random ending point !
@Every endpoint change, i am required to re-log-in.
‎2025-02-16 10:58 PM
now code generating tool is loading since 30 min
‎2025-02-17 12:11 AM
eventually you can mark this as the solution - to help other developers
‎2025-02-17 4:46 AM
https://raimechaeropvtltd.slack.com/archives/D086W24BE8H/p1739794329899899
I tried to generate code by setting up pin assignments in STM32CubeIDE with reference to the following site for the generating code in stm32cubeide version 1.17.0.
