clicking login redirects to microsoft login page unless I open private window
Clicking login redirects to Microsoft login page unless I open a private window.
It redirects to https://login.microsoftonline.com. But login in there doesn't work.
I use firefox.
Kudo posts if you have the same problem and kudo replies if the solution works.
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
30 REPLIES 30
@unsigned_char_array wrote:
I get logged out automatically on a daily basis.
That's normal behaviour here. Timeout is significantly less than a day.
