X-CUBE_AI 8.1.0 Tutorial
SKuma.43
Kindly provide a step-by-step procedure or tutorial on how to use generated C code from X-CUBE-AI 8.1.0.
How to use embedded client API (generated by X-CUBE)?
Minimal application is provided in Documentation section. If possible kindly provide any elaborate tutorial for working with X-Cube-AI 8.1.0.
1 REPLY 1
STTwo-32
Hello @SKuma.43
I suggest you take a look at this MOOC. Also, you can use the UM2526. You can find more documents in the Documentation folder of the package.
Best Regards.
STTwo-32
