When running the command: python stm32ai_main.py --config-path--config-name,error:the same file
llcc
D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src>python stm32ai_main.py --config-path ./config_file_examples/ --config-name my_deployment_n6_ssd_mobilenet_v2_fpnlite_config.yaml
2025-05-16 11:30:17.018496: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'cudart64_110.dll'; dlerror: cudart64_110.dll not found
2025-05-16 11:30:17.018747: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
[WARNING] The usable GPU memory is unlimited.
Please consider setting the 'gpu_memory_limit' attribute in the 'general' section of your configuration file.
[INFO] : Running `deployment` operation mode
[INFO] : ClearML config check
[INFO] : The random seed for this simulation is 123
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
[INFO] : Generating C header file for Getting Started...
[INFO] : This TFLITE model doesnt contain a post-processing layer
loading model.. model_path="D:/stm32aibushu/stm32ai-modelzoo/object_detection/ssd_mobilenet_v2_fpnlite/ST_pretrainedmodel_public_dataset/coco_2017_person/ssd_mobilenet_v2_fpnlite_035_192/ssd_mobilenet_v2_fpnlite_035_192_int8.tflite"
loading conf file.. "../../application_code/object_detection/STM32N6/stmaic_STM32N6570-DK.conf" config="None"
"n6 release" configuration is used
[INFO] : Selected board : "STM32N6570-DK Getting Started Object Detection (STM32CubeIDE)" (stm32_cube_ide/n6 release/stm32n6)
[INFO] : Compiling the model and generating optimized C code + Lib/Inc files: D:/stm32aibushu/stm32ai-modelzoo/object_detection/ssd_mobilenet_v2_fpnlite/ST_pretrainedmodel_public_dataset/coco_2017_person/ssd_mobilenet_v2_fpnlite_035_192/ssd_mobilenet_v2_fpnlite_035_192_int8.tflite
setting STM.AI tools.. root_dir="", req_version=""
Cube AI Path: "D:\stm32edgeai\stedgeai\2.1\Utilities\windows\stedgeai.exe".
[INFO] : Offline CubeAI used; Selected tools: 10.1.0 (x-cube-ai pack)
compiling... "ssd_mobilenet_v2_fpnlite_035_192_int8_tflite" session
model_path : ['D:/stm32aibushu/stm32ai-modelzoo/object_detection/ssd_mobilenet_v2_fpnlite/ST_pretrainedmodel_public_dataset/coco_2017_person/ssd_mobilenet_v2_fpnlite_035_192/ssd_mobilenet_v2_fpnlite_035_192_int8.tflite']
tools : 10.1.0 (x-cube-ai pack)
target : "STM32N6570-DK Getting Started Object Detection (STM32CubeIDE)" (stm32_cube_ide/n6 release/stm32n6)
options : --st-neural-art default@../../application_code/object_detection/STM32N6/Model/user_neuralart.json --input-data-type uint8 --inputs-ch-position chlast
[returned code = 4294967295 - FAILED]
$ cwd: None
$ args: D:\stm32edgeai\stedgeai\2.1\Utilities\windows\stedgeai.exe generate --target stm32n6 -m D:/stm32aibushu/stm32ai-modelzoo/object_detection/ssd_mobilenet_v2_fpnlite/ST_pretrainedmodel_public_dataset/coco_2017_person/ssd_mobilenet_v2_fpnlite_035_192/ssd_mobilenet_v2_fpnlite_035_192_int8.tflite --output D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\experiments_outputs\2025_05_16_11_30_18 --workspace D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\experiments_outputs\2025_05_16_11_30_18 --st-neural-art default@../../application_code/object_detection/STM32N6/Model/user_neuralart.json --input-data-type uint8 --inputs-ch-position chlast
ST Edge AI Core v2.1.0-20194 329b0e98d
PASS: 0%| | 0/92 [00:00<?, ?it/s]
PASS: 12%|█▏ | 11/92 [00:16<01:59, 1.48s/it]
PASS: 13%|█▎ | 12/92 [00:17<01:56, 1.46s/it]
PASS: 17%|█▋ | 16/92 [00:17<01:08, 1.11it/s]
PASS: 20%|█▉ | 18/92 [00:18<00:57, 1.30it/s]
PASS: 21%|██ | 19/92 [00:18<00:50, 1.46it/s]
PASS: 22%|██▏ | 20/92 [00:18<00:44, 1.63it/s]
PASS: 24%|██▍ | 22/92 [00:19<00:32, 2.15it/s]
PASS: 25%|██▌ | 23/92 [00:19<00:28, 2.39it/s]
PASS: 27%|██▋ | 25/92 [00:19<00:20, 3.29it/s]
PASS: 28%|██▊ | 26/92 [00:19<00:18, 3.63it/s]
PASS: 29%|██▉ | 27/92 [00:19<00:16, 3.88it/s]
PASS: 35%|███▍ | 32/92 [00:20<00:07, 7.81it/s]
PASS: 37%|███▋ | 34/92 [00:20<00:08, 7.13it/s]
PASS: 38%|███▊ | 35/92 [00:20<00:08, 6.97it/s]
PASS: 39%|███▉ | 36/92 [00:20<00:08, 6.70it/s]
PASS: 40%|████ | 37/92 [00:20<00:08, 6.58it/s]
PASS: 41%|████▏ | 38/92 [00:21<00:08, 6.48it/s]
PASS: 42%|████▏ | 39/92 [00:21<00:08, 6.37it/s]
PASS: 43%|████▎ | 40/92 [00:21<00:08, 6.31it/s]
PASS: 45%|████▍ | 41/92 [00:21<00:08, 6.11it/s]
PASS: 46%|████▌ | 42/92 [00:21<00:08, 6.00it/s]
PASS: 47%|████▋ | 43/92 [00:21<00:08, 5.93it/s]
PASS: 48%|████▊ | 44/92 [00:22<00:07, 6.12it/s]
PASS: 49%|████▉ | 45/92 [00:22<00:07, 6.02it/s]
PASS: 50%|█████ | 46/92 [00:22<00:07, 6.06it/s]
PASS: 51%|█████ | 47/92 [00:22<00:07, 6.03it/s]
PASS: 52%|█████▏ | 48/92 [00:22<00:07, 5.98it/s]
PASS: 53%|█████▎ | 49/92 [00:22<00:07, 6.02it/s]
PASS: 54%|█████▍ | 50/92 [00:23<00:06, 6.01it/s]
PASS: 55%|█████▌ | 51/92 [00:23<00:06, 5.90it/s]
PASS: 57%|█████▋ | 52/92 [00:23<00:06, 5.74it/s]
PASS: 58%|█████▊ | 53/92 [00:23<00:06, 5.65it/s]
PASS: 59%|█████▊ | 54/92 [00:23<00:06, 5.78it/s]
PASS: 60%|█████▉ | 55/92 [00:23<00:06, 5.88it/s]
PASS: 63%|██████▎ | 58/92 [00:24<00:03, 8.58it/s]
PASS: 64%|██████▍ | 59/92 [00:24<00:05, 6.55it/s]
PASS: 65%|██████▌ | 60/92 [00:24<00:05, 6.15it/s]
PASS: 67%|██████▋ | 62/92 [00:24<00:04, 6.72it/s]
PASS: 68%|██████▊ | 63/92 [00:25<00:04, 6.39it/s]
PASS: 70%|██████▉ | 64/92 [00:25<00:04, 6.13it/s]
PASS: 71%|███████ | 65/92 [00:25<00:04, 5.84it/s]
PASS: 72%|███████▏ | 66/92 [00:25<00:04, 5.65it/s]
PASS: 73%|███████▎ | 67/92 [00:25<00:04, 5.42it/s]
PASS: 74%|███████▍ | 68/92 [00:26<00:04, 5.35it/s]
PASS: 75%|███████▌ | 69/92 [00:26<00:04, 5.37it/s]
PASS: 76%|███████▌ | 70/92 [00:26<00:04, 4.46it/s]
PASS: 77%|███████▋ | 71/92 [00:26<00:04, 4.45it/s]
PASS: 78%|███████▊ | 72/92 [00:26<00:04, 4.71it/s]
PASS: 80%|████████ | 74/92 [00:27<00:02, 6.09it/s]
PASS: 82%|████████▏ | 75/92 [00:27<00:02, 5.93it/s]
PASS: 84%|████████▎ | 77/92 [00:27<00:02, 7.07it/s]
PASS: 85%|████████▍ | 78/92 [00:27<00:02, 6.52it/s]
PASS: 86%|████████▌ | 79/92 [00:27<00:02, 5.91it/s]
PASS: 87%|████████▋ | 80/92 [00:28<00:02, 5.71it/s]
PASS: 88%|████████▊ | 81/92 [00:28<00:01, 5.53it/s]
PASS: 89%|████████▉ | 82/92 [00:28<00:01, 5.46it/s]
PASS: 90%|█████████ | 83/92 [00:28<00:01, 5.36it/s]
PASS: 91%|█████████▏| 84/92 [00:34<00:15, 1.92s/it]
>>>> EXECUTING NEURAL ART COMPILER
D:/stm32edgeai/stedgeai/2.1/Utilities/windows/atonn.exe -i "D:/stm32aibushu/stm32ai-modelzoo-services/object_detection/src/experiments_outputs/2025_05_16_11_30_18/ssd_mobilenet_v2_fpnlite_035_192_int8_OE_3_2_0.onnx" --json-quant-file "D:/stm32aibushu/stm32ai-modelzoo-services/object_detection/src/experiments_outputs/2025_05_16_11_30_18/ssd_mobilenet_v2_fpnlite_035_192_int8_OE_3_2_0_Q.json" -g "network.c" --load-mdesc "D:/stm32edgeai/stedgeai/2.1/Utilities/configs/stm32n6.mdesc" --load-mpool "D:/stm32aibushu/stm32ai-modelzoo-services/application_code/object_detection/STM32N6/Model/my_mpools/stm32n6-app2.mpool" --save-mpool-file "D:/stm32aibushu/stm32ai-modelzoo-services/object_detection/src/experiments_outputs/2025_05_16_11_30_18/neural_art__network/stm32n6-app2.mpool" --out-dir-prefix "D:/stm32aibushu/stm32ai-modelzoo-services/object_detection/src/experiments_outputs/2025_05_16_11_30_18/neural_art__network/" --all-buffers-info --no-hw-sw-parallelism --cache-maintenance --enable-virtual-mem-pools --native-float --optimization 3 --Os --Omax-ca-pipe 4 --Ocache-opt --enable-epoch-controller --output-info-file "c_info.json"
<<<< DONE EXECUTING NEURAL ART COMPILER
PASS: 91%|█████████▏| 84/92 [00:37<00:15, 1.92s/it]
PASS: 92%|█████████▏| 85/92 [00:38<00:17, 2.55s/it]
LOAD ERROR: WindowsPath('D:/stm32aibushu/stm32ai-modelzoo-services/object_detection/src/experiments_outputs/2025_05_16_11_30_18/network.h') and WindowsPath('D:/stm32aibushu/stm32ai-modelzoo-services/object_detection/src/experiments_outputs/2025_05_16_11_30_18/network.h') are the same file
$ cwd: None
Error executing job with overrides: []
Traceback (most recent call last):
File "D:\anaconda\lib\site-packages\clearml\binding\hydra_bind.py", line 230, in _patched_task_function
return task_function(a_config, *a_args, **a_kwargs)
File "D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\stm32ai_main.py", line 228, in main
process_mode(cfg)
File "D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\stm32ai_main.py", line 102, in process_mode
deploy(cfg)
File "D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\../deployment\deploy.py", line 111, in deploy
stm32ai_deploy_stm32n6(target=board, stlink_serial_number=stlink_serial_number, stm32ai_version=stm32ai_version, c_project_path=c_project_path,
File "D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\../../common/deployment\common_deploy.py", line 469, in stm32ai_deploy_stm32n6
stmaic_local_call(session)
File "D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\../../common/deployment\common_deploy.py", line 443, in stmaic_local_call
stmaic.compile(session=session, options=opt, target=session._board_config)
File "D:\stm32aibushu\stm32ai-modelzoo-services\object_detection\src\../../common\stm32ai_local\compile.py", line 208, in cmd_compile
raise Exception('Error during compilation')
Exception: Error during compilation
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
29 REPLIES 29
LQC_
You can set the my_deployment_n6_ssd_mobilenet_v2_fpnlite_config.yaml Is the content of this file pasted out? I'll try.
*This post has been translated from Chinese to comply with the ST Community guidelines.
llcc
The problem has just been solved! Thank you! I'm currently getting a similar error to yours:
LQC_
Okay, what error caused this? I'll take precautions too.
llcc
It should still be a problem with the config file my_deployment_n6_ssd_mobilenet_v2_fpnlite_config.yaml, I deleted all the paths and filled them in again, then ran it again and it ran successfully, thank you!
llcc
https://community.st.com/t5/edge-ai/stm32n6570-dk-model-zoo-delpoyment-error/m-p/784139#M4163 Have you tried this, I did and it didn't work, the build worked, but when I set the N6 boot pin to the right and connected it to the PC, it's screen flashed for a second, then the screen went black and LD3,4 both turned red at the same time!
LQC_
Did you solve that problem? How was it solved. As for your comment about the screen flickering and then the lights turning red, it's due to a lack of power supply.
LQC_
You could use another 5v-USB_SNK port for power and try again. As for how to use it, you reverse the development version, there are three jumpers next to each other, replace the first jumper cap on top of the second jumper, which is on top of the USB-SNK, and try again?
HarisHer
llcc
It still didn't work, I got this error after running the script file, then I tried the method I just mentioned, after a successful build with the N6 boot pin set to the right and powered by 5v-USB_SNK, the screen didn't respond when I connected it to the PC.
llcc
Maybe because I'm using a USB to Type-C cable (USB-A to USB-C)?
