model zoo Object detection
MH24
I want to implement an application for detecting items in the kitchen on an STM32-H747i-DISCO board. I installed Python 3.10.2, TensorFlow 2.8, CUDA 11.7, and cuDNN v8.8.1. After installing the model zoo , I tried running the command in  Command Prompt python stm32ai_main.py , from this path " ..\stm32ai-modelzoo\object_detection\src".  But I encountered the attached error
I
Laurent FOLLIOT
As this is path related issue, could you create a new virtual environment either with Conda or python?
This should avoid such issues.
Thanks & Regards,
5 REPLIES 5
Laurent FOLLIOT
Could you share your yaml file please?
We do not reproduce the issue as this time on last model zoo version.
MH24
Attached is the yaml file
Thank you
Thanks,
Do you confirm that you cloned the repository from GitHub, without code modification and that preprocess.py file is well cloned in src/preprocessing folder?
MH24
yes I confirm
Laurent FOLLIOT
Thanks & Regards,
