INTERNAL ERROR: tuple index out of range
‎2020-10-13 6:49 AM
‎2023-01-19 8:54 AM
This model is supported starting X-CUBE-AI version 7.2
Daniel
‎2023-01-19 9:03 AM
After analysis the problem is likely to come from the usage of nested models.
Maybe you can try to rewrite the same topology with no or less nested levels
Daniel
‎2023-01-19 9:57 AM
Your model is correctly supported now with X-CUBE-AI 7.3
Daniel
‎2023-05-15 3:13 PM
Daniel -
I finally got back to this. You were right. Once I removed the model nesting, the analysis worked correctly. I am glad I can even use multi-input Keras models.
Thank you!
‎2023-12-29 12:12 AM
Hello all,
In version 8.1.0 Cube AI Cloud, I implemented a machine learning model by using Keras.
I had an error and couldn't solve it.
INTERNAL ERROR: Unconsistent data. Filter size [2], strides (2,), in_shape(1, 240).
I checked my model and everything seems okey. My model has 3 inputs (X, Y, Z) and 6 output labels. I had constructed bunch of segments according to dataset. With this error text, which things should I control or change?
Can you help me with that? Thank you.:.
Regards.
‎2024-09-30 12:33 PM
Facing Same issue now, Running XCube AI version 9.0.0 unable to analyze or validate my network.
- « Previous
- 1
- 2
- Next »
