2024-06-21 1:47 AM
I'm following introductory course on Embedded AI, the course used Cube-Mx AI 3.4.0 AI Package, which generated a 'Data Processor .c' file. we need the file to insert user code for our application. But no where in the file structure in the up-to-date 9.0.0 could be found. Please advise if there is equivalent file in the generated code.
Best regards
2024-06-21 9:28 AM
I'll continue with the assumption this Data-Process file is added to the project not generated by cubeMX. The instructor did not hint this is the case.
