2025-05-19 11:07 PM - last edited on 2025-05-20 6:15 AM by Peter BENSCH
Hi Team,
I am facing to connect with SR5E1-EVBE7000P board. I give below the issue. Can anyone help me to resolve this issue
Error in final launch sequence:
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Don't know how to run. Try "help target".
-exec-run
2025-05-20 7:04 AM
Hello ,
Which version of StellarStudio and openocd do you use ?
COuld you check openocd version plugin ?
Best Regards
Erwan
2025-05-20 9:41 PM
Hi Erwan,
I am using
Open On-Chip Debugger 0.11.0+dev-gf194ae73a (2023-03-03-09:26)
StellarStudio-7.1
saikrishna.
2025-05-20 9:44 PM
Can i get setup documentation SR5E1-EVBE7000P board with stellar studio and example code.
2025-05-21 2:03 AM
Hello ,
we have updated the version into
$ ./openocd --version
Open On-Chip Debugger 0.12.0+dev-01351-gce9e33791-dirty (2024-11-21-12:34)
Check the document How to use OpenOCD and StellarLINK in StellarStudio.pdf inside c:\StellarStudio-7.1\openocd\docs\
For your information ,
StellarStudio 7.2.0 officially pushed (Compliant f... - STMicroelectronics Community
Best regards
Erwan
2025-05-21 4:21 AM
After installing stellar studio 7.2.0. I followed the documents. But Still I am getting this error
Licensed under GNU GPL v2
For bug reports, read
"http://openocd.org/doc/doxygen/bugs.html"
adapter srst delay: 100
Started by GNU MCU Eclipse
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
best regards,
saikrishna.
2026-04-30 5:05 AM
Hi
Has there been any progress on this issue please as I have the same problem.
Many thanks in advance.
