SPC584xx CAN Booloader Example - Is there a PC Side application from STMicro?
SKara.7
Is there a PC Side application available from STMicro to test flashing via CAN?
I was able to find the CAN Bootloader example for SPC584xx-EVAL Board, but is there a PC side application to test the flash programming?
Best regards,
Sreejith
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
4 REPLIES 4
ODOUV.1
no, we have a test application for UART/bootloader but not for CAN/bootloader
Best Regards
Generally companies building CAN hardware have specific experience, and PC side hardware preferences as these tend to be specialized and niche.
Find CAN adapters with good PC support, drivers, and DLLs for C, C#, etc interfacing to user created apps.
Thanks. Could you please share the link to PC Side UART/Bootloader application?
SKara.7
Apparently, I found SPC5-Flasher tool in st.com website in ht ebelow link. But, once I try to install, it is asking for serial number.
Please let me know how to get the serial number.
Link to SPC5-Flasher below.
https://www.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/spc5-embedded-software/spc5-software-tools-and-drivers/spc5-flasher.license=1657285456961.product=SPC5-FLASHER.version=2.8.0.html
