SPC560D40L1 : How to implement Watchdog Timer
harsh2
Posted on June 12, 2016 at 21:51
Dear All
I want to rum a timer in my MCU: SPC560D40L1.
I am using SPC 5studio.
Please advise, if i can generate the code for any specific duration watchdog timer or what documents i should refer to rum a timer.
Awaiting for your kind reply.
Thanks in advance !!
Harsh
2 REPLIES 2
procolo
Senior
Posted on June 13, 2016 at 08:43
Hi Harsh,
regarding the timer we already discussed about in this topic
[DEAD LINK /public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/SPC56/SPC560D40L1%20Timer&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058]SPC56D40L1: Timer
For Watchdog, you can find related information on RM Chap.30. If you need more help, please let us know which kind of application are you going to implement and we can provide specific example code.
Regards,
Procolo
harsh2
Posted on June 13, 2016 at 13:37
Hi Procolo
I am working on automotive application, in which i am intending to drive LCD display using GPIOs of [DEAD LINK /public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/SPC56/SPC560D40L1%20Timer&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058]SPC56D40L1MCU.
i asked for related sample code for this in other discussion.
LCD's datasheet attached with below mentioned technical specs:
Specifications:
1. Operating Temperature: -30 to +85 deg C.
2.Storage temperature: -40 to 95 deg C
3.Operating Voltage: 5V
4. LCD Type: TN Positive
5.Connection type: Pin type
6.Clock viewing: 6'o clock
7. Drive condition: 1/4 DUTY, 1/3 BIAS
8.Display type: Trasflective
9.Polarizer colour: Grey
Polarizer: High quality anticlar.
Vibration On cluster: freq: 30-500Hz.
Please help me in this case.
Harsh
________________
Attachments :
LCD_display_-_Electronics.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htdl&d=%2Fa%2F0X0000000aSB%2FhuQy7WJxs.xZHgjDcOCkYj_8AALxNl3blJRzeAmj.tg&asPdf=false
