Saradc configuration.
‎2022-02-01 10:05 AM
I'm having trouble configuring saradc , as shown in the attached figure. I'm working on core 2 while on core 0 there is a program already made using the GTM module. Is there any relationship? Any suggestions to fix the attached error? Thanks!!
‎2022-02-27 2:55 PM
SPC5_SARADC12_SV_DMA_MUX0_DEV_ID is defined in spc58xe_registry.h
However for SPC58xE it should be defined to 1
Regards.
‎2022-02-27 2:55 PM
Regards.
