Problem with Lin Enable filters
nooshin_1382
Posted on August 12, 2015 at 11:01
Hi
I Have 2 problems with Lin :
1.When i Recive a data from LIN I have  No interrupt
2.When i want to set a filter in LIN the programm not work at this point in the attachment code :
LINFLEX_1
.IFMR.B.IFM=1;
LINFLEX_1.IFER.R=0;  I attach my code .
Best Regards
Nazerian Vanima
2 REPLIES 2
Erwan YVIN
Posted on August 17, 2015 at 11:46
Hello Vanima ,
I am checking your code , today
Best regards
               Erwan
Erwan YVIN
Posted on August 17, 2015 at 15:55
Hello Vanima ,
On B Devices : you can not access to these registers on LINFlex_1
LINFLEX_1.IFMR.B.IFM=1;
LINFLEX_1.IFER.R=0;
If you want to use the filter mode,you have to use the LinFlex_0. (cf chapter 2), 16 identifier filters for autonomous message handling in Slave mode. (q.) Only LINFlex0 supports slave mode. Best regards Erwan
