Problem with Flexcan2 and Flexcan3 in spc560b50L5
nooshin_1382
Posted on March 14, 2015 at 19:51
Hi
I have a 3channel can board for my project , i work with Flexcan1 with out any problem but when i want to work with Flexcan2 or 3 with a same config they did not work or any action.
here is my code :
automatically.*/
#include''components.h''
#include''can_lld_cfg.h'' </p>
</b>
#define led1 SIU.GPDO[102].B.PDO
#define led2  SIU.GPDO[103].B.PDO
#define led3 SIU.GPDO[105].B.PDO
#define FM SIU.GPDO[69].B.PDO
#define CAN_EN SIU.GPDO[71].B.PDO
#defineASSR_EN SIU.GPDO[44].B.PDO </p>
</b>
CANTxFrame
txmsg;
int
main(
void
    componentsInit();
      osalIsrEnable();
canStart(&CAND3,&can_config_canls);
SIU.
PCR
[102].
B
OBE
=1;
SIU.
PCR
[103].
B
OBE
=1;
SIU.
PCR
[105].
B
OBE
=1;
SIU.
PCR
[69].
B
OBE
=1;
SIU.
PCR
[71].
B
OBE
=1;
SIU.
PCR
[44].
B
OBE
=1;
SIU.
PCR
[42].
B
PA
=1;
SIU.
PCR
[42].
B
OBE
=1;
SIU.
PCR
[43].
B
IBE
=1;
SIU.
PCR
[35].
B
PA
=0;
SIU.
PCR
[35].
B
OBE
=1;
SIU.
PCR
[95].
B
PA
=0;
SIU.
PCR
[95].
B
OBE
=1;
 txmsg.
IDE
= CAN_IDE_STD;
txmsg.
RTR
= CAN_RTR_DATA;
txmsg.
LENGTH
= 8;
txmsg.
data32
[0] = 0x55AA55AA;
txmsg.
data32
[1] = 0x00FF00FF; ////////////////////
led1 = 1;
led2 = 1;
led3 = 1;
FM = 1;
CAN_EN=1;
ASSR_EN=1;
/* Application main loop.*/
while
(1){
CAND2.flexcan->BUF[2].CS.B.IDE=0U;
CAND2.flexcan->BUF[2].CS.B.RTR=0U;
CAND2.flexcan->BUF[2].ID.B.STD_ID=0x325;
CAND2.flexcan->BUF[2].CS.B.LENGTH=7;
CAND2.flexcan->BUF[2].DATA.B[0]=0x89;
CAND2.flexcan->BUF[2].DATA.B[1]=0x66;
CAND2.flexcan->BUF[2].DATA.B[2]=0x77;
CAND2.flexcan->BUF[2].DATA.B[3]=0x44;
CAND2.flexcan->BUF[2].DATA.B[4]=0xee;
CAND2.flexcan->BUF[2].DATA.B[5]=0xaa;
CAND2.flexcan->BUF[2].DATA.B[6]=0xbb;
CAND2.flexcan->BUF[2].CS.B.CODE=0X0C;
led2 = ~led2;
osalThreadSleepMilliseconds(500);
i use the SPCStudio function's but get the same answer
Please Help About this issue
Best Regards Vanima
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
3 REPLIES 3
Erwan YVIN
Posted on March 17, 2015 at 15:05
Hello Vanima ,
Did you configure your PADSEL Correctly ?
(Cf screenshot)
for FlexCan2 and FlexCan3 you should configure PADSEL1 and PADSEL2
Best regards
Erwan
________________
Attachments :
2015-03-17_145709.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hyst&d=%2Fa%2F0X0000000bZj%2FdXeLa68hCgTfuRNFUnskok3H3ew8mWze.DB.Xmwzi0Q&asPdf=false
nooshin_1382
Posted on March 19, 2015 at 11:47
Hello Erwan
I configure the PADSEL and everything is ok.
Thanks a lot , it is completely solved my problem and very usefull .
with Best Regards
Vanima
Erwan YVIN
Posted on March 19, 2015 at 17:26
Good news
Erwan
