osalThreadDelayMilliseconds not working in spc584-dis
LBona.2
hi during the debug of my program with UDE it gets stuck on osalThreadDelayMilliseconds i found in the forum that the problem may be a PIT configuration problem but i don't know how to set it.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Hello ,
Could you send us the PIT configuration ?
I recommend you to take SPC584Bxx_RLA PIT Test Application for Discovery as example
Best Regards
Erwan
2 REPLIES 2
Erwan YVIN
Hello ,
Best Regards
Erwan
LBona.2
i didn't set any particular PIT configuration. I only wanted to put a delay for slower the execution of a function during debugging.
#include "components.h"
#include <math.h>
#include <stdlib.h>
float u_alfa = -1000;
float u_beta = -10;
float Vdc = 600;
float fsw = 17000;
char gates[6];
void spaceVectorMod(float u_alfa,float u_beta, float Vdc, float fsw, char * gates, float tzero);
int main(void) {
  /* Initialization of all the imported components in the order specified in
     the application wizard. The function is generated automatically.*/
	componentsInit();
	float tzero=0;
	while(true){
		spaceVectorMod(u_alfa, u_beta,  Vdc,  fsw,  gates,  tzero);
		osalThreadDelayMilliseconds(300);
