In SPC584Bx i2c hw driver we have seen for single byte read we observed that NACK and stop condition is generated after 256 bytes and not after single byte and for 2 bytes it is generated after 1 byte.
VChav.2
It seems to be bug in driver. Please confirm.
Erwan YVIN
Hello Vchav ,
I am submitting an Error report in our tracker.
Do you use I2C driver coming from SPC584Bxx_RLA I2C Test Application for Discovery  ?
Best Regards
Erwan
3 REPLIES 3
Erwan YVIN
Hello Vchav ,
Best Regards
Erwan
VChav.2
Hello Erwan,
Thank you for your response.
Yes I am using the same I2C HW driver coming from SPC584Bxx_RLA I2C Test Application for Discovery.
Thank you.
Best Regards,
Vijayalakshmi Chavan.
Angelo Castello
could you please share more details, like example code, i2c clock used, oscillator snapshot and so on.
