I am trying to configure UART using SPC560B Dis Board. UART mode isn't getting initialised. Code is attached herewith. How to solve the issue?
Pooja WANI
Erwan YVIN
Hello ,
Is it a crash ?
Do you use RLA components ?
we have a lot of UART examples in SPC5Studio (SPC560B Dis Board)
I recommend you to compare the initialization of UART
Best Regards
Erwan
3 REPLIES 3
Erwan YVIN
Hello ,
Is it a crash ?
Best Regards
Erwan
Pooja WANI
Yes, I am using RLA components. This issue got resolved. However, UARTSR.DRF bit is not getting set while reception of data. And TO bit is getting set.
What can be the issue over here?
Thanks and Regards,
Pooja WANI
Pooja WANI
I could run the UART successfully without using "Init Package Component RLA". However, if I add this component, my code gets stuck at
"0x000000E0:  78 00 00 00 E_B    _IVOR1 (0x000000E0)"
Because of this, I am not able to use Interrupt_based UART.
How to resolve this issue?
Thanks and Regards,
Pooja WANI
