2020-02-06 09:46 PM
2020-02-10 06:43 AM
Hello ,
Strange to see that there is an error on Git Icone
org.eclipse.swt.SWTException: i/o error (java.io.FileNotFoundException: C:\Program Files\Git\mingw64\share\git\git-for-windows.ico (The system cannot find the path specified))
at org.eclipse.swt.SWT.error(SWT.java:4533)
I recommend you to switch back into SPC5Studipo Perspective and use the button generate and compile button
(Cf Screenshot)
Best regards
Erwan
2020-02-07 05:31 AM
Hello ,
Could you send us the log located in c:\SPC5Studio\workspace\.metadata\ ?
Have you generated from SPC5Studio tools suite ?
Best regards
Erwan
2020-02-09 09:12 PM
2020-02-10 06:43 AM
Hello ,
(Cf Screenshot)
Best regards
Erwan
2020-02-18 11:54 PM
I did the same thing as you explained in above screenshot still i am getting an error that launching binary failed and CDT path variable is not specified as showed in the screenshot which is shared by me now.
2020-02-20 12:59 AM
I did the same thing as you shown in the screenshot but i am not able to enable the "Execute and Debug your application".
Can you please share me any tutorials present for this SPC5Studio.
2020-03-02 10:29 PM
Hai Erwan,
While I am trying to enabling the "Execute and Debug section".
Showing that could not found this website, the following is the website and the website given in help section to install the PLS UDE debugger also showning this site is not found.
SPC5tools - http://spc5.drive.cloudforge.com/projects/spc5tools/updates/
2020-03-04 08:22 PM
