2019-05-01 05:06 AM
i have two project one is bootloader and other is application.for downloading purpose i have pls usb/jtag adapter and ude visual platform 4.4 which only programme .elf file. i have knowledge how to combine two hex file .but dont know how to convert hex file to elf file.
i can convert elf to hex using command
objcopy.exe -O ihex out.elf out.hex
but don't know how to convert reverse??
and is there any other way of doing this?
2019-05-01 09:51 AM
This is on Linux for 32-bit ARM, but should work on all architectures and platforms:
$ file foo.elf
foo.elf: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), statically linked, not stripped
$ arm-none-eabi-objcopy -O ihex foo.elf foo.hex
$ file foo*
foo.hex: ASCII text, with CRLF line terminators
$ head -4 foo.hex
:020000042002D8
:1000000000C00720B9030220C5020220C702022057
:10001000C9020220CB020220CD020220CF02022020
:10002000D1020220D3020220D5020220D7020220F0
$ arm-none-eabi-objcopy -I ihex -O elf32-littlearm foo.hex foo2.elf
$ file foo*
foo2.elf: ELF 32-bit LSB relocatable, no machine, version 1, stripped
$ wc -c foo*
3246308 foo.elf
2870 foo.hex
1192 foo2.elf
3250370 total
Note that the foo2.elf copy is much smaller than foo.elf because foo.elf was compiled with -g and has lots of debug data that was lost in the conversion to hex.
Again, this is for ARM32. Do "objcopy --help" to see a list of supported ELF formats and choose the one that matches your original out.elf file.
2019-05-01 10:36 PM
i have spc5668g powerpc core.and here is snapshot of objcopy -h but i dont know which one is used by spc studio to generate .elf
2019-05-01 11:47 PM
Try doing "objdump.exe -a" or "objdump.exe --archive-headers" (might be ""objdump.exe /a", ""objdump.exe /archive-headers" on Windows) and see if the file format it reports matches any of the ones reported by "objcopy --help".
