how to compile code on a particular address.i have to write the application for that or i can use some tools for that.
RRama.8
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Hello ,
You can create your own linker file (user.ld) and use __attribute__
__attribute__ ((section (".codeinram"))) void gotoStandbyMode(void) {
	WKUP.WISR.R = 0x00000008;		//Clear interrupt flag
	if ((ME.GS.B.S_CURRENTMODE < SPC5_RUNMODE_RUN3)
	      || (ME.GS.B.S_CURRENTMODE > SPC5_RUNMODE_RUN0)) {
	    if (OSAL_FAILED == halSPCSetRunMode(SPC5_RUNMODE_STANDBY)) {
	      SPC5_CLOCK_FAILURE_HOOK();
__attribute__ ((section (".codeinram"))) void gotoRunMode(void)
	    if (OSAL_FAILED == halSPCSetRunMode(SPC5_RUNMODE_DRUN)) {
Best Regards
Erwan
2 REPLIES 2
That's usually the function of the LINKER
A Linker Script would define memory regions and names of sections
The compiler would use attribute or #pragma to flag to the linker the section names the user has provided.
Where the tools lack I've built linkers and object file manipulation/translation apps.
Erwan YVIN
Hello ,
Best Regards
Erwan
