2019-06-17 12:01 AM
Hello
I was trying to run Sample Test Code from application wizard into my ECU(SPC560B40L3) but it doesn’t worked out.
I’ve attached the snapshot. Could you please help me out into this?
2019-06-27 7:42 AM
Hello ,
it seems to be a crash issue
check LR,R14 in the debugger to check where the crash is located.
the error display c:\SPC5Studio\tmp
are you the right to access to this directory ?
Best regards
Erwan
2019-06-27 7:42 AM
Hello ,
Best regards
Erwan
