Hello All, I am working on SPC563M64 MCU with XPC563M Board. I need to read/write memory locations through JTAG. Can anyone suggest some application examples? Thanks!
KST
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
3 REPLIES 3
Angelo Castello
Good morning,
Hoping to have understood your question, why could not use a debugger to read/write target memory via JTAG ?
Regards,
Angelo
Presumably the OP wants to do testing/diagnostics, outside the classical debugging sense. ie things JTAG was designed for, scan chain testing, boundary scan, checking internal memories, etc..
Perhaps you have some comprehensive documentation on the implementation, or a white paper for debugger writers, etc.
Angelo Castello
is it clear your goal and the only suggestion that i can you is to look at http://openocd.org/. This offer you a full support to JTAG interface as well a good documentation as reference for your goal. I think you need only to added the low lever JTAG interface to communicate with our JTAG Debug interface.
Hoping to help you,
Regards,
Angelo
